Volume Levels - NEED HELP! | SatelliteGuys.US
Nic
2
Fargo, ND
Hello experts! I have something that is driving me crazy, and I am a very experienced Googler who has not found the same problem asked anywhere else. I need your help.
I recently installed a Vizio sound bar to pair with my Samsung TV. I currently have DISH Network and easily set up the remote to work with my new sound bar. I am loving it so far. Great sound.
Here is the part that is driving me crazy: When I use the sound bar remote, the volume ascends at a very reasonable rate. Usually by a half-step each time according to the display. It is perfect. When I use the DISH remote, however, it ascends by a full step each time, which has a BIG impact on the volume levels. It is far too much.
Is there a way to "throttle down" the DISH remote or TV settings to react in a similar way to the Vizio remote?
Perhaps try the other Vizio codes, perhaps one is more up to date with smaller volume settings. If your Dish remote is programmable you could program the volume using your Visio remote.
I have never looked up a code for this remote setup. Our Hopper/Joey systems automatically configure the remote for us. Looks like I'll have to do some research on this.
And I think this is a Samsung code problem, not a Vizio code problem. The sound bar is connected with an optical cable, so all commands are coming from the television - maybe. I'm no expert.
Perhaps you could try navigating through the Vizio codes or reset them. I believe there will always be a slight difference between the quality from the sound bar and Dish. If all else fails, contact Vizio support.
curved TVs
Home theater in a box
