[VOOM/DISH/OTA] Can I still use my stealth? | SatelliteGuys.US
R
rhtbep
Guest
You did not mention whether you kept the V* box and are using it for OTA or not. Sounds like that you did not keep the box, and in that case would have to attempt to use the Stealth unamplified. Power for the amplifier was from the V* box. No harm in trying to use it, but you may have to remove the pre-amp from the antenna. Or perhaps find a power supply that you can use in lieu of the STB.
E
Re: [VOOM/DISH/OTA] Re: Voom only pick up part of PBS
E
[VOOM/DISH/OTA] "Activated" Voom Box, how do I verify?
