[VOOM/DISH/OTA] Re: NO SIGNAL | SatelliteGuys.US
  • Thread starter Thread starter irv6744
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
I
irv6744
Guest
it's fairly simple actually
go to the website below and do some reading. you have to get to the
installation menus (zoom + green + green)and check signal strength
for one or two frequencies and then do a station scan and then you
should be good to go if your antenna is good enough for digital
reception. i get a strong signal but no digital because i am going
through trees. am trying to put up a mast and go over the trees. good
luck
http://www.satelliteguys.us/forumdisplay.php?f=44
--- In VOOM@yahoogroups.com, "almaureenblue" <bluebird93@a...> wrote:
> I just received a voom with the latest software. I must be doing
> something wrong. I can't get any signal. The list of local
channels
> is not for my area. Chicago. It is pretty frustrating. The present
> antenna is Jensen 920. I just purchased the new TERK HDTVLP
> LOW PROFILE INDOOR ANTENNA. Any help in getting unit to work would
> be
> greatly appreciated.
I
[VOOM/DISH/OTA] ota scan problems / trees
A
[VOOM/DISH/OTA] NO SIGNAL
