[VOOM] DVI Connection | SatelliteGuys.US
S
Stan Sexton
Guest
Wow! Just switched from a Component connection to DVI from the VOOM STB to
my Sony 50" LCD HDTV and the picture is definitely superior.
This has to be the way to go with a fixed-pixel display!
Stan in San Diego
I see no difference on my 46" CRT-based Toshiba CinemaSeries using a
Monster DVI cable and cheap component video cables given to me with
one of my HD boxes (can't remember which provider).
On Fri, 31 Dec 2004 13:19:39 -0800, thegrod <bruceg@htva.net> wrote:
> Stan,
> You really SEE a difference between component and DVI? New poll needed
> because I barely do if at all. Curious what others have to say on this. I
> hope Robert is listening in.
> Thegrod
> ----- Original Message -----
> From: "Stan Sexton" <stanathomesell@cox.net>
> To: <VOOM@yahoogroups.com>
> Sent: Friday, December 31, 2004 10:57 AM
> Subject: [VOOM] DVI Connection
> to
> > Stan in San Diego
> > Yahoo! Groups Links
How do I word the poll question? How's this?
Which method of hookup do you use?
A. DVI and the picture is much better than component
B. DVI and the picture is the same as component
C. Component and could the picture be any better? No!
C. Component and I wish the picture were better
D. I don't have an HDTV yet :-(
Robert Heitner Jr.
Data Developers Plus, Corp.
281.538.2886 X106
<blocked::http://www.ddpcorp.com> http://www.ddpcorp.com
Home of the #1 Contact Management Solution!
<blocked::BLOCKED::http://www.riatacrm.com/> http://www.riatacrm.com
_____
From: Jarrett Campbell [mailto:jarrett@engineer.com]
Sent: Friday, December 31, 2004 3:33 PM
To: VOOM@yahoogroups.com
Subject: Re: [VOOM] DVI Connection
> Stan,
I
> Thegrod
> to
> > Stan in San Diego
> > Yahoo! Groups Links
I think it is important to find out what type of display the user is
watching too as I feel that those with CRT monitors will have a
different distribution than those with LCD or DLP based solutions.
Not sure how you can matrix all that info together. I've been trying
to figure out how to have a multiple question survey for another Yahoo
Group I run.
Jarrett
On Fri, 31 Dec 2004 15:40:37 -0600, Robert Heitner <ddprobert@yahoo.com> wrote:
> Robert Heitner Jr.
> 281.538.2886 X106
> _____
> > Stan,
> I
> > Thegrod
> STB
> > to
> > > Stan in San Diego
> > > Yahoo! Groups Links
Looks good.
Sent: Friday, December 31, 2004 1:40 PM
Subject: RE: [VOOM] DVI Connection
> Robert Heitner Jr.
> 281.538.2886 X106
> _____
>> Stan,
> I
>> Thegrod
>> STB
>> to
>> > Stan in San Diego
>> > Yahoo! Groups Links
>> Yahoo! Groups Sponsor
>> ADVERTISEMENT
>> ________________________________
>> Yahoo! Groups Links
>> To visit your group on the web, go to:
>> http://groups.yahoo.com/group/VOOM/
>> To unsubscribe from this group, send an email to:
>> VOOM-unsubscribe@yahoogroups.com
>> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> Hey do you sass that hoopy Jarrett Campbell? Now there's a frood who
> really knows where his towel is!
> ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=129aavega/M=298184.5639630.6699735.3001176/D=gr
> oups/S=1705036932:HM/EXP=1104615195/A=2495208/R=0/SIG=11egg01lg/*http://www.
> netflix.com/Default?mqso=60188914> click here
> <http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=groups/S=
> :HM/A=2495208/rand=338575311>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> <mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
> [Non-text portions of this message have been removed]
> Yahoo! Groups Links
I don't notice a large difference between component and DVI on my Sammy DLP. So I am using component for my Voom stb and DVI for my Bravo D2 DVD player.
I too used to use DVI on my Sammy DLP, but now use component on the TV, and DVI on the Sammy DVD player..definately made the DVD picture better! Dont notice much difference on the Satalite picture...All cables are Monster Preimium series...
Stan,
Thegrod
> Stan in San Diego
> Yahoo! Groups Links
[VOOM] Re: DVI Connection Problem
I use a Monster DVI to HDMI cable and it works fine with my Sony
KD-34XBR960.
The problem lies with either the cable, your tv set, or the Motorola
box. You should check your HDMI input with another device (if
available) to eliminate the possibility that your tv or cable is
faulty.
I once had a set-top box from Cablevision's IO digital cable service
that would not accept a DVI input and would give me a similar error
message. It turned out that the box was faulty. A new box solved the
problem.
--- In VOOM@yahoogroups.com, "Foxworth, John D." <FOXWORJ@r...> wrote:
> Please have some one check about using the HDMI to DVI. I have a
JVC DILA that uses an HDMI port. When I connect my HDMI to DVI
> cable to the STB, I get an error on the screen that indicates there
is a DVI CONFLICT THAT NEEDS TO BE RESOLVED. I have made sure
> the STB is powered off while connecting the cable.
> Any thoughts.
> THANKS & HAVE A GREAT DAY!!
> *John D. Foxworth*
> *(336) 741-1415
> 7 (336) 728-7590 (FAX)
> * <mailto:*foxworj@r...> foxworj@r...
<http://thehub.rjr.com/corporatelogos/ReynoldsAmer
icanLogos/WebGIFandJPEG/ra7511highres.jpg>
> PRINCIPLED CREATIVE DYNAMIC PASSIONATE
> -----Original Message-----
> From: thegrod [mailto:bruceg@h...]
> Sent: Friday, December 31, 2004 4:20 PM
> Stan,
needed
this. I
> Thegrod
> From: "Stan Sexton" <stanathomesell@c...>
VOOM STB to
> > Stan in San Diego
> > Yahoo! Groups Links
> ADVERTISEMENT
> click here
<http://us.ard.yahoo.com/SIG=129m84msu/M=295196.49
01138.6071305.3001176/D=groups/S=1705036932:HM/EXP
=1104614387/A=2128215/R=0/SIG=10
> se96mf6/*http://companion.yahoo.com>
<http://us.adserver.yahoo.com/l?M=295196.4901138.6
071305.3001176/D=groups/S=:HM/A=2128215/rand=688664930>
> Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
> CONFIDENTIALITY NOTE: This e-mail message, including any
attachment(s),
> contains information that may be confidential, protected by the
attorney-
> client or other legal privileges, and/or proprietary non-public
> information. If you are not an intended recipient of this message
or an
> authorized assistant to an intended recipient, please notify the
sender by
> replying to this message and then delete it from your system. Use,
> dissemination, distribution, or reproduction of this message and/or
any of
> its attachments (if any) by unintended recipients is not
authorized and
> may be unlawful.
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
Please have some one check about using the HDMI to DVI. I have a JVC DILA that uses an HDMI port. When I connect my HDMI to DVI
cable to the STB, I get an error on the screen that indicates there is a DVI CONFLICT THAT NEEDS TO BE RESOLVED. I have made sure
Any thoughts.
*John D. Foxworth*
*(336) 741-1415
* <mailto:*foxworj@rjrt.com> foxworj@rjrt.com
<http://thehub.rjr.com/corporatelogos/ReynoldsAmericanLogos/WebGIFandJPEG/ra7511highres.jpg>
Stan,
Thegrod
> Stan in San Diego
> Yahoo! Groups Links
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129m84m...036932:HM/EXP=1104614387/A=2128215/R=0/SIG=10
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=:HM/A=2128215/rand=688664930>
Yahoo! Groups Links
VOOM-unsubscribe@yahoogroups.com <mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
CONFIDENTIALITY NOTE: This e-mail message, including any attachment(s),
contains information that may be confidential, protected by the attorney-
information. If you are not an intended recipient of this message or an
authorized assistant to an intended recipient, please notify the sender by
dissemination, distribution, or reproduction of this message and/or any of
its attachments (if any) by unintended recipients is not authorized and
may be unlawful.
Yahoo! Groups Links
wase4711
This message was posted via http://www.satelliteguys.us by wase4711
Yahoo! Groups Links
DVD player.
jimmykce1
This message was posted via http://www.satelliteguys.us by jimmykce1
Yahoo! Groups Links
I too used my dvi connection on my Sammy DLP to connect to my Denon DVD player; picture is almost as good as the best HD transmission; using Monster M3 on all my stuff, the component connection from my VOOM box to the tv shows no real difference than it did when I was using DVI & VOOM...
BTW, the Denon DVD player has superior video AND audio than the Sammy DVD/DVI player it replaced, and its only a few $$$ more than the Sammy..Money well spent, and it plays almost every kind of disc you stuff into it...
M
[VOOM] Help AVS
H
Re: [VOOM] rain fade?
