[VOOM] Fw: Use and LG LST-3410A as a hard drive recorder | SatelliteGuys.US
  • Thread starter Thread starter Stan Sexton
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
S
Stan Sexton
Guest
Fellow VOOMers - You may find this Q&A informative for those of you who
want to record OTA.
----- Original Message -----
To: "Stan
Sent: Sunday, December 19, 2004 1:29 PM
Subject: Use and LG LST-3410A as a hard drive recorder
> Here's what our customers tell us:
> The LG LST-3410A hard drive recorder can probably do what you're asking
> for
> since it has firewire inputs and outputs.
> The LG 3410 can only record satellite HDTV when connected to our product
> setup.
> The 3410A also provides basic editing and can be used for recording from
> a
> DirecTV HDTV box that has our upgrade installed.
> The LG LST-3410A can be used instead of a DVHS deck, except that the
> built
> in hard drive isn't removable, at least not easily. Some of our
> customers
> report mounting a removable hard drive in the 3410A with great success.
> The LG LST-3410A can also be used with a DVHS deck to record from its
> internal hard drive to a tape for long term storage and viewing later.
> Setup 1)
> 169time upgraded recevier >>> AVX1 >>> 3410A >>> monitor
> Setup 2)
> 3410A >>> DVHS deck >>> monitor
> Windows Media 2005 is for particular hardware boxes that are licensed to
> run
> it. The capabilities of the particular box will vary from one vendor to
> another. Ask the vendor if their particular box can record from
> firewire.
> Windows Media 2005 is intended to be a complete solution pre-built. It
> is
> also possible to do the same thing by collecting hardware and software as
> explained in the hard drive recording section of our web page. We do not
> have feedback yet on using Windows Media 2005 boxes with our product.
> When
> we do we'll put in on our web page.
> Today, the 3410 is a working way to accomplish hard drive recording of
> HDTV
> from our product without the need to use Windows computers or software
> that
> are tricky to set up and operate.
> Thanks
> Susan
> Subject: Re: Sony DHG-HDD250 and DHG-HDD500
>> Thanks, Susan!
>> Can you tell me if a Hard Disk recorder can be used instead of a DVHS
> deck?
>> Are there any hard disk recorders that take a firewire input?
>> Any PC based hardware and software that can be used to record on a PC?
>> Also, can Windows Media Center 2005 be used to record off firewire?
>> Thanks
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
S
[VOOM] I got a email from a person from Voom::::
R
[VOOM] Voom and Analog channels
