Well installer called and is on his way ! They have the dish and STB but not the upgraded ant .
Will keep you posted after the install !
johnfaas said:Well installer called and is on his way ! They have the dish and STB but not the upgraded ant .
johnfaas said:Installer came and everything went good ! Looks good so far !
One thing , I seem to be loosing some of the pic (like it is expanded or something ) like the news on top is cut off ?
I have 65 mitsu wide HDTV should I change something on the Voom settings ?
Yes let me know !deArgila said:I have the same TV - and the same issue. I think it's just overscan on the part of the Mits (as I think I've hooked up the box to my Dell 17" LCD and didn't have the overscan issue.
It would be nice to know if there's anything I can do to change it. Anyone else know?
get into your hidden service menu on you tv and change horizontal and vertical stretch and position. then redo your convergence points. Heres a link to get into your service menu.deArgila said:I have the same TV - and the same issue. I think it's just overscan on the part of the Mits (as I think I've hooked up the box to my Dell 17" LCD and didn't have the overscan issue.
vurbano said:get into your hidden service menu on you tv and change horizontal and vertical stretch and position. then redo your convergence points. Heres a link to get into your service menu.
http://www.keohi.com/keohihdtv/brandspecific/mitsubishi/mitsu_servicecodes.html
FYI I use discoveryHD channel and its logo to set the lower right corner and Worldsports awful soccer scoreboard to set the upper left corner (it is extremely close to the edge of the picture) If you can get those two things on your screen on those two channels youve done a pretty good job. And are getting about the Whole picture.
The tec came and fixed the over scan prob than did a re cal.Now I can see the whole top on the news and the clock on the games !johnfaas said:Installer came and everything went good ! Looks good so far !
Limited time offer
