voom install: can i use existing echo* dish | SatelliteGuys.US
jeffdan
88
hello i've had dish for over ten years. i do have the superdish with high def equipment. i have two questions
1. can i use existing dish to voom.
2. is voom really worth the switch. pic quality?
hello. could you tell me why it is not compatible? i have an older 18" dish. would that one?
If you have 18" E* dish aimed at 61 (old E* HD & Internation location), then you can connect it directly to Voom without any changes. That is what I did with my E* dish. It works great.
A.
multipathing??
RG6 cable for VOOM
