[VOOM] Looks like VOOM lives . . | SatelliteGuys.US
D
David Landsman
Guest
Cablevision tells Sears that Voom service will continue
Cablevision Systems executives have told the retail giant that a deal has
been reached to save the Voom satellite-TV service. A spokeswoman for Sears,
Roebuck and Co., the largest seller of Voom services, says it has been
assured that Voom will carry on. The Wall Street Journal (subscription
required) (3/7)
Not all that telling, unfortunately. Could be wishful thinking or just an empty promise.
Hey all. After all my DVI issues with my Sammy DLP - it's fixed now and
looks great (after 3 months effort). We need to light candles - or whatever
will work!!!
-----Original Message-----
From: David Landsman [mailto:davidlandsman@comcast.net]
Sent: Monday, March 07, 2005 2:37 PM
To: VOOM@yahoogroups.com
Subject: [VOOM] Looks like VOOM lives . .
required) (3/7)
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129ls52of/M=298184.6018725.7038619.3001176/D=gr
oups/S=1705036932:HM/EXP=1110316378/A=2593423/R=0/SIG=11el9gslf/*http://www.
netflix.com/Default?mqso=60190075>
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
* To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
[Non-text portions of this message have been removed]
[VOOM] Re: Looks like VOOM lives . .
Jeff. what was the issue ??? I never had a problem using my DVI with
VOOM on my Sammy.
now and
whatever
> will work!!!
> From: David Landsman [mailto:davidlandsman@c...]
deal has
for Sears,
been
(subscription
> required) (3/7)
> ADVERTISEMENT
> click here
6/D=gr
//www.
> _____
> Yahoo! Groups Links
of
RE: [VOOM] Re: Looks like VOOM lives . .
The DVI problem I had with my Sammy hlp-6163w is that components work fine.
The DVI problem is that every couple of minutes the screen will blank out
for a second or two. it does it every two minutes or so and is unusable! I'
ve had Voom send me a different DVI cable - different STB - change
resolutions - update software, etc. I went to best buy and "borrowed" a
Phillips HD OTA and DVD combo with DVI outputs. It worked just fine on my
Sammy. Sammy repairman came out twice and replaced the DVI digital board –
to no avail. I have a second Voom receiver (which is newer than my first
one) that I swapped out when this problem happened thinking it was a
receiver issue – but had the same blinking problem on that STB. Well, just
for giggles I tried it again (after 2 months and Voom had software upgrades
done to it) – wouldn't you know it that it works fine now. The only
conclusion I can think of that it's a very peculiar compatibility problem
with the older STB and the Sammy. Maybe those digital boards on the Sammy
were bad – maybe they weren't.
Sent: Monday, March 07, 2005 4:29 PM
Subject: [VOOM] Re: Looks like VOOM lives . .
VOOM on my Sammy.
now and
whatever
> will work!!!
deal has
for Sears,
been
(subscription
> required) (3/7)
> ADVERTISEMENT
> click here
< http://us.ard.yahoo.com/SIG=129ls52of/M=298184.6018725.7038619.300117
6/D=gr
//www.
> _____
> Yahoo! Groups Links
of
> Service < http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129nkctoo/M=298184.6018725.7038619.3001176/D=gr
oups/S=1705036932:HM/EXP=1110317500/A=2593423/R=0/SIG=11el9gslf/*http://www.
_____
Yahoo! Groups Links
The normal website is back at www.voom.com and at www.voomllc.com.
--- In VOOM@yahoogroups.com, "David Landsman" <davidlandsman@c...>
deal has
for Sears,
been
(subscription
> required) (3/7)
[VOOM] Re: Voom Lives and DVR thoughts...
Only the 'get it' page is still 'unavailable'.
Good to see the new channels, although I could do without most of them
personally, it's great to have a bit more variety.
In response to some of the other folks and the vapor-dvr, I could
honestly live without a dvr if they would put a firewire port on the
existing box. I know people have discussed that topic into the ground
as well but would sure love to understand the resistance to that.
Sam
S
[VOOM] Sound sync on TCM?
E
Re: [VOOM] Re: Voom Lives and DVR thoughts...
