[VOOM] Re: DVI Connection Problem | SatelliteGuys.US
  • Thread starter Thread starter seattlesatelliter
  • Start date Start date
  • Replies Replies 0
  • Views Views 847
S
seattlesatelliter
Guest
Some of you might be interested in the controversy over in the General
section of the <audioasylum.com> about Monster Cable sueing other
companies over the use of "monster" in their name. Very interesting.
Watching HDTV under very cold clear Seattle skies, Gill
--- In VOOM@yahoogroups.com, "sandman9r" <sandman9r@y...> wrote:
> I use a Monster DVI to HDMI cable and it works fine with my Sony
> KD-34XBR960.
> The problem lies with either the cable, your tv set, or the Motorola
> box. You should check your HDMI input with another device (if
> available) to eliminate the possibility that your tv or cable is
> faulty.
> I once had a set-top box from Cablevision's IO digital cable service
> that would not accept a DVI input and would give me a similar error
> message. It turned out that the box was faulty. A new box solved the
> problem.
> --- In VOOM@yahoogroups.com, "Foxworth, John D." <FOXWORJ@r...> wrote:
> > Please have some one check about using the HDMI to DVI. I have a
> JVC DILA that uses an HDMI port. When I connect my HDMI to DVI
> > cable to the STB, I get an error on the screen that indicates there
> is a DVI CONFLICT THAT NEEDS TO BE RESOLVED. I have made sure
> > the STB is powered off while connecting the cable.
> > Any thoughts.
> > THANKS & HAVE A GREAT DAY!!
> > *John D. Foxworth*
> > *(336) 741-1415
> > 7 (336) 728-7590 (FAX)
> > * <mailto:*foxworj@r...> foxworj@r...
> <http://thehub.rjr.com/corporatelogos/ReynoldsAmer
> icanLogos/WebGIFandJPEG/ra7511highres.jpg>
> > PRINCIPLED CREATIVE DYNAMIC PASSIONATE
> > -----Original Message-----
> > From: thegrod [mailto:bruceg@h...]
> > Sent: Friday, December 31, 2004 4:20 PM
> > To: VOOM@yahoogroups.com
> > Subject: Re: [VOOM] DVI Connection
> > Stan,
> > You really SEE a difference between component and DVI? New poll
> needed
> > because I barely do if at all. Curious what others have to say on
> this. I
> > hope Robert is listening in.
> > Thegrod
> > ----- Original Message -----
> > From: "Stan Sexton" <stanathomesell@c...>
> > To: <VOOM@yahoogroups.com>
> > Sent: Friday, December 31, 2004 10:57 AM
> > Subject: [VOOM] DVI Connection
> > > Wow! Just switched from a Component connection to DVI from the
> VOOM STB to
> > > my Sony 50" LCD HDTV and the picture is definitely superior.
> > > This has to be the way to go with a fixed-pixel display!
> > > Stan in San Diego
> > > Yahoo! Groups Links
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
> > click here
> <http://us.ard.yahoo.com/SIG=129m84msu/M=295196.49
> 01138.6071305.3001176/D=groups/S=1705036932:HM/EXP
> =1104614387/A=2128215/R=0/SIG=10
> > se96mf6/*http://companion.yahoo.com>
> <http://us.adserver.yahoo.com/l?M=295196.4901138.6
> 071305.3001176/D=groups/S=:HM/A=2128215/rand=688664930>
> > ________________________________
> > Yahoo! Groups Links
> > * To visit your group on the web, go to:
> > http://groups.yahoo.com/group/VOOM/
> > * To unsubscribe from this group, send an email to:
> > VOOM-unsubscribe@yahoogroups.com
> <mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/> .
> > CONFIDENTIALITY NOTE: This e-mail message, including any
> attachment(s),
> > contains information that may be confidential, protected by the
> attorney-
> > client or other legal privileges, and/or proprietary non-public
> > information. If you are not an intended recipient of this message
> or an
> > authorized assistant to an intended recipient, please notify the
> sender by
> > replying to this message and then delete it from your system. Use,
> > dissemination, distribution, or reproduction of this message and/or
> any of
> > its attachments (if any) by unintended recipients is not
> authorized and
> > may be unlawful.
> > [Non-text portions of this message have been removed]
R
[VOOM] Voom and Analog channels
S
Re: [VOOM] Package Suggestion
