[VOOM] remote control | SatelliteGuys.US
S
slriv
Guest
The remote control provides a means of programming the TV button to
manipulate your TV and it does that fine. I even sort of like the way
you program it. It's a lot better than other ones I've used.
Anyway, if I configure it to switch my TV on and off, it's volume and
mute controls only work on the TV. Is there a way I can leave the
power putton to turn on/turn off the TV but the volume and other audio
features control my receiver? As it stands, I'm stuck using two
remotes (actually much more, but that's unrelated). I tried also to
program the TV button to manipulate my receiver instead but it didn't
have the code for it (which I expected actually).
Any suggestions? Any hidden features here that I can try?
I have the same issue as I wish I could operate my Dennon receiver as thats what I use for surround sound. If you find out please do share.
Matt
----- Original Message -----
To: VOOM@yahoogroups.com
Sent: Tuesday, February 01, 2005 5:31 PM
Subject: [VOOM] remote control
Yahoo! Groups Links
a.. To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
b.. To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[Non-text portions of this message have been removed]
I asked the same question after having been spoiled by the remote to
my E* 811. The answer is "nope". I'm stuck with 3 remotes at this
point.
sbh
> ________________________________
> Yahoo! Groups Links
[VOOM] Re: remote control
I found a way to control the volume of my tv and my surround sound.
Since my Sony tv has audio out, I ran some audio cables to my pre-
amp audio inputs, so now when I change the volume on my tv, the
stereo speakers change volume also. Remember to set your tv volume
first, then adjust the stereo up to the right balance.
Unfortunately that won't work for this. I don't have any audio going
to the TV/monitor. I was hoping there was some hidden functionality
somewhere that might make this simpler, but it looks like a universal
remote is in my future.
A
[VOOM] Thanks
B
[VOOM] Ground hog day
