vooms61.5- and Dish 61.5 using dual lnb | SatelliteGuys.US
nevrluz
4
Can I use a Dish 500 oval dual lnb to get both voom and Dish international with one dish since they are both 61.5. Or do I have to have 2 seperate dishes mounted pointing in the same direction? thanks in advance.
The Voom dish will include a dual LNB, which means it has a single actual LNB with dual outputs. You can always use one of the outputs for Voom and one for Dish 61.5. The signaling will be similar to legacy, so you can't easily integrate it into a dishpro setup but you can always switch them around performing a switch check each time ;).
cant pinpoint my problem neither can voom
Sean, where is your cool title picture?
