VPN router recomendations | SatelliteGuys.US
Paradox-SJ
1,636
2
San Jose, California
I am looking to buy a router with VPN capabilities that has enough throughput to pass HD when doing site to site tunnel.
Is there anyone running this setup?
I use a Draytek 2930 Dual Wan Router for home use. It allows me to load balance and VPN with no problems. However, most people don't need/use a dual WAN system, so there are cheaper options the OP may want to explore.
You are correct I do not NEED a dual WAN solution... I just need reliable site to site tunneling with high through put capabilities. I didn't think it would be that hard to find something :-(
You are going to have to find a router where you can flash DD-WRT to replace the installed operating system. Then you can run a PPTP VPN to accomplish what you want. Not a trivial process if you are uncomfortable working with a router. Also possible that you will brick your router if you make a mistake.
Jim
