Wally single tuner Mode | SatelliteGuys.US
Unpluggedtech
18
4
lawrenceville
Been running 6 Wally’s in a small commercial setup using a DPP44 and a DP34,. Starting loosing satellites, now check switch is returning dual tuner but I don’t believe DPP44 or DP34 can support this. trued the DPH42 with no success
The DPP44 will; the DP34 will not. Recommend replacing the DP34 with a DPP33, cascaded off the DPP44, if you can find one.
Reactions: dishdude
