C ctibbs New Member Original poster Jul 13, 2018 3 4 FL Jul 13, 2018 #1 Is there a way to wire 2 wally's to a 1000.2 eastern arc hybrid antenna and get all channels for both wally's?
pattykay formerly crodrules Jun 14, 2014 8,620 7,751 North Central Ohio Jul 13, 2018 #2 ctibbs said: Is there a way to wire 2 wally's to a 1000.2 eastern arc hybrid antenna and get all channels for both wally's? Click to expand... One cable directly from each Wally to each output on the LNB should work. Reactions: NYDutch, comfortably_numb and charlesrshell
C ctibbs New Member Original poster Jul 13, 2018 3 4 FL Jul 13, 2018 #3 I will try that. Reactions: NYDutch and pattykay
C ctibbs New Member Original poster Jul 13, 2018 3 4 FL Jul 13, 2018 #4 BTW Thanks, Ill let you know if it worked. C Reactions: NYDutch and pattykay
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,668 29,759 Rohnert Park, CA Jul 13, 2018 #5 And of course you will have to activate that second Wally and pay $7 a month for its use... I realize you didn't say just how you want to use that Wally but I thought I'd bring up the obvious. Reactions: NYDutch
