L lmn1220 Active SatelliteGuys Member Original poster Jul 10, 2008 20 0 Oct 2, 2008 #1 hi, i have a dual receiver 522 want to upgrade to dual recvr dvr. i was looking at the 625. is there another one below that? or what are all my choices? thanks again
C chainblu SatelliteGuys Pro Aug 25, 2006 641 111 Oct 2, 2008 #2 A 625 is exactly the same as a 522, but with a larger hard drive. Both of your threads are still a little confusing. Maybe a 510 is what you want? It;s a single tuner DVR, but a lot less flexible than a 522.
B BobaBird SatelliteGuys Pro Sep 8, 2003 1,693 0 EKB Annex Oct 2, 2008 #3 i have a dual receiver 522 want to upgrade to dual recvr dvr. i was looking at the 625. is there another one below that? Click to expand... Look Marge, you're soaking in it! You either already have a DVR but aren't taking advantage of it, or you misidentified what you have (double-check the front panel and/or Sys Info screen). Or maybe we're not sure what you want from an upgrade.
