just ordered the dish but need the dual lnbf. anyone have one for sale? looking to turn into glorystar system. thanks. PM me if you have one you want to sell.
The holder holds one lnbf, but lnbf's come in single (one output) and twin (two outputs), some people call them dual's.
Edit: This is what a single looks like:
KUL1 0.4db Noise figure Sadoun Standard Linear Offset LNBF LNB
This is what a twin/dual looks like:
KUL2 Dual Output 0.4db Noise figure Sadoun Standard Linear Offset LNBF LNB
This is a monoblock single for 2 sats @ 4 degrees apart:
KLB1 0.4db Sadoun Monoblock Linear Offset LNBF LNB
This is a monoblock twin/dual for 2 sats @ 4 degrees apart:
KLB2 0.4db Sadoun Monoblock Dual Linear Offset LNBF LNB
This is a holder for an lnbf:
LNBHolder1 40mm KU-band LNBF Holder for Offset Dishes
This is an holder for 3 lnbf's:
3 LNBF Holder
This is a holder for 4 lnbf's:
4 LNBF Holder
Hope this helps....!!
Oh the 2 LNB holder for the Glorystar system?
Like the 2nd pic here
http://www.satelliteguys.us/glorystar-support-forum/93282-glorystar-dual-lnb-upgrade-kit.html
Glorystar sells the kit with the holder and 2 LNB's
otherwise you could just ziptie/hoseclamp the LNB's together.
Yep. We FTA'ers do it all the time
Have a look in the FTA area. If you get the 2 LNB bracket that is designed for the Glorystar system it only works with the LNB they sell. Hoseclamp you can use any LNB
http://www.satelliteguys.us/fta-shack/131140-pics-dish-farm-post-yours-too.html
Limited time offer
