warm up cycle then off | SatelliteGuys.US
dumbjim
20
st. louis mo.
Help! My beloved DSR922 is behaving strangely. After roughly 5 mins., it clicks off then goes through the warm up cycle, will work for another 4 or five mins., then bang, it does it again. I've tried unplugging it for several minuets but that doesn't correct the issue. Any ideas?
Yup, bad LNB or cable... There's a protection circuit in the DSR series of receivers, that will shut it down if too much current is drawn at the LNB port, such as a short in the cable somewhere, or the LNB itself.
As an after thought. It's great you can post a problem and in less than 24 hrs. get advice from people who know what their talking about.
Thanks!
C-band LNBS strange problem
Who all are using combo C/KU LNBFs
