Washington DC - HD Channels Out During Storm | SatelliteGuys.US
wvu_nova
11
During most heavy rainstorms my HD channels go out. I can watch the Non-HD version of ESPN, but not the HD version, I get the error, "searching for satellite 771". Does anyone know why this is? This gets real old.
Check your signal readins for the 99(c) and 103(c) satellites, which is where most of the HD is located at. You should have readings in the upper 80's to lower 90's on a clear day, if not the dish might need a slight realignment.
Also, the Ka band that's used for the 99 and 103 satellites is more sensitive to rain fade, which is why having the dish properly aligned is more important then for the old SD channels.
May I suggest that others who may read this thread and have similar problems to supply their signal strengths. This way we won't need to ask for that info.
Phone line connection question....
NFL Superfan
