Folks,
How do I go about setting up a stable tripod here?
I can see this install is going to leave me without hair![]()
Thanks for that Jerry. I've got this far;Either make a form and pour a concrete slab or sink a pole in the ground.
I had a very similar installation of a T90 where I poured a triangle shaped slab, still working great.
lnb with four outputs.What is a quad lnb?
Yes, thats right.You scanned in all the channels with out a switch, Right?
Well, I have four of them (Global) - all straight out of the box. Will check the others when I get back to it next week.Sounds like a bad diseqc switch.
Will double check cable ends and config.Diseqc switching problems;
Poor cable ends,
wrong switch configurations,
ground loop between reciever and dish.
I have the switches fastened along the dishes mount. The receiver - by default - is grounded once its plugged in is it not?Ground loop is when two different ground points are used. A stake in the ground out at the dish and then the receiver is grounded to the house electrical service. The two points transfer electricity between them through the shielding of the cables. Diseqc switches see this current flow as nosie or sometimes as commands.
Limited time offer
