FOR SALE - Wavlink AC3200 Dual Band 2.4/5 GHz Gigabit Router, Designed by Jacob Jensen, Model RCNE-WN538A8-WL MU-MIMO, New & Sealed | SatelliteGuys.US
FOR SALE Wavlink AC3200 Dual Band 2.4/5 GHz Gigabit Router, Designed by Jacob Jensen, Model RCNE-WN538A8-WL MU-MIMO, New & Sealed
FTA4PA
Satellite Guys Family
8,260
6,768
Central Pennsylvania
I have a sealed Wavlink AC3200 Quantum Dax MU-MIMO Dual Band 2.4/5 GHz Gigabit Router, Jacob Jensen design, model number RCNE-WN538A8-WL, for sale. I purchased this and another cheaper router when our daughter and her family moved back in with us temporarily. They had to have Wi-Fi, which we don't use ourselves. Since it was just a temporary situation, I used the cheap router. This one was put aside and never opened so it is still new in the box. As I said, we don't use Wi-Fi and have no use for it. I'm asking $25 plus shipping. Will consider a reasonable offer though. If interested, message me so we can work out the details. PayPal only please. Thanks! :)
From the manufacturer
  • Complies with IEEE 802.11ac/a/n/g/b with the leading 802.11ac WAVE2 standard
  • Simultaneous 5GHz 2167Mbps and 2.4GHz 1000Mbps connections up to 3167Mbps of total available bandwidth
  • 8 x 5dBi Omni-Directional Antennas provide even better wireless performance
  • Provides 1 x 10/100/1000Mbps Ethernet WAN port
  • Provides 3 x 10/100/1000Mbps Ethernet LAN port
  • USB3.0 Port - share files & media with networked devices
  • Support PPTP and L2TP. Simple to build up safe Internet connection.
  • Remote Access enables you to be proactive about network when you are away from home.
  • MU-MIMO communicates with several devices at once to reduce waiting time and speed up connections
  • Built-in firewall features IP and MAC filtering which flexibly controls online access and time
  • Built-in DHCP server with automatic dynamic IP address distribution
  • At the top, there is a LCD screen, you can see the current network status
  • Easy Setup Assistant with multi-language support provides a quick & hassle-free installation process
