Wavy Lines | SatelliteGuys.US
Wavy Lines
LoTech
498
Whitesburg, Kentucky
I have my Coolsat 8000 set up on top of my TV (An old 32 inch CRT Samsung HDTV monitor). When I had my receiver hooked up SD using a composite RCA jack everything was just fine (except it was SD). When I upgraded to Component cables for the HD channels I had a great quality picture, except I noticed some wavy lines running through the picture. They look like analog FM interference except running horizontal rather than vertical. Most of the time they aren't bad, but sometimes they are quite visible. Has anyone else had this problem with a set top box?
yeah specially if it is on top of the tv. move it away and you will see. and you better use the RCA cables as components them since they seem to perform better against EMI, lol.
scary movie on KTV2?
OpenBox Diseqc Switch Commands ?
