Weather Boots no longer required | SatelliteGuys.US
RandallA
10,556
68
San Francisco Bay Area
I found this today in the Tech Portal. Weather boots are no longer required for Dish Network installations. I don't know if this is good but don't complain if you installer didn't install the weather boots outside.
Weather boots are one of those "damned if you do, damned if you don't" kinda things. The problem is that while they usually keep moisture out, they always keep moisture in.
Forget the torque wrench. Just run the nut down and apply just a little more pressure.
Silicone grease, 100% non-handining, should be applied right on the tip of the center conductor. None is needed om the nut threads. The part most vulnerable to galvanic corrosion is the center conductor and socket. To avoid the "air gap," the center white foam dielectric must stick into the center ferule at the botom of the nut. As Londoners say, "MIND THE GAP!"
Place the connection horizontal. Any moisture that gets in runs out.
Personally, for high end installs, everything goes into a weatherproof boxm with bottom entries and exits. The cable and telephone companies learned this a long time ago.
"Personally, for high end installs, everything goes into a weatherproof boxm with bottom entries and exits. The cable and telephone companies learned this a long time ago"
I'm not an installer but this is what I've done at home. I don't leave any connection or switch in the open.
alaska dish size
Scott: Question about HD Locals
