Weather Channel audio really low | SatelliteGuys.US
dcowboy7
676
Pequannock, NJ
anyone notice the Weather Channel audio is really low ?
other stations i put on a 25 while i need to got to 40 for them.
Good luck...
in communicating this to Directv. I've noticed the problem for a couple of months. It isn't effecting the SD, just the HD feed.
I also emailed the Weather Channel, so...??? and you have the result!
If you are connected HDMI from DirecTV direct to TV; then try going into the DirecTV audio menu and turn OFF dolby digital.
Does that help? My audio is on par with the other chnls.
Installation in progress - signal strength?
Why such poor guide data?
