Weird 522 Bug? | SatelliteGuys.US
Weird 522 Bug?
shippy1973
24
3 times in the past week (since the L236 upgrade I guess) I have had a show that I have scheduled to record from 10-11...start and record for 1 min, stop, then it picks up and records again at either 8 or 12 minutes into the show for the remainder. Anyone else get this? It is ONLY this one show that does it. Very weird.
The first two times it was 8 minutes (last week), today it was at 12 minutes. I am afraid it may be 16 minutes the next time.... But it does not do it every day?? :confused:
Me too . I've had more problems with L236 than I've ever had in the past .
Others problems:
Have to hit the power or select button twice to get the unit to turn on.
Unit goes into diagnostics for no apparent reason .
L237 is starting to spool now and hopefully will "fix" these problems .
Wow. This is the first time I've seen them list three software versions at the same time. Looks like the're putting out bug fixes faster than it takes to roll out the last version.
More often than not, HBO does not record the whole program on channel 300, for some reason. Either the channel is dropping out, or my remanufactured 522 is doing it. It happened before the 236 update, too. Other HBO's seem to be OK. We had signal loss on HBO with our 4DTV system, but not this often.
522 problem
522 issues (yes me too)
