Weird remote problem | SatelliteGuys.US
  • Thread starter Thread starter CopyChief
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
CopyChief
SatelliteGuys Guru
145
2
Ever since my 522 was installed, I've had a weird remote problem. I have a Panasonic TV as TV1, so the IR remote is programmed to it. All the functions of the TV work fine with the remote, except the volume control is "sticky." I press it up, and it moves up two or three clicks. The installer tried two different IR remotes and both had the same problem.
Oddly enough, I tried remote from TV2 and programmed it with the codes for the other TV and it didn't "stick", everything was fine. Did I just get two bad remotes or has anyone else had this problem?
thanks in advance.
Is RG6 Wire RG6 Wire?
Help guys
