Well I'm Voomin | SatelliteGuys.US
Well I'm Voomin
obi010
6
The install went great the HD stuff is nice. But the only problem I have is that I get zero local channels?!?! The installer said he did another install in my area and that person also got no locals :confused: . What I wanted to know is if anyone in Bridgeport, CT also has voom and do you have any locals??
Options
You're really far away from the towers so I'm not sure if upgrading you to a bigger antenna plus a preamp would be at all helpful. :( I'm wondering if Voom would "let you" pick up the New York networks? (Anyone?)
If everything else fails, you could try getting your HD locals through Cable. For instance, here in Middletown, all you need is to subscribe to the limited basic lineup, get a decoder with QAM (unscrambled) capability, and you're all set!
Good luck.
(Try searching in the avsforums.com)
Martin-
Another Successful Voom Install!
Newb Question: 8vsb adapter
