Trying to pull Detroit stations from the Saginaw/Bay City area zip 48706. I'm having no luck with a CM4228, 7775 pre-amp, and rotor. I can't get anything from Lansing either @ 60 miles. Any other suggestions?
Jim5506 said:Those distances are "over the horizon" for UHF reception. You might have some luck going higher and using ganged yagi's, but UHF reception beyond 60 miles is not guaranteed, especially if there are terrain issues (mountains, etc.)
Jim5506 said:...especially if there are terrain issues (mountains, etc.)
Jim5506 said:If the 4228 and CM7775 get nothing whereas the Silver Sensor can, I'd check to be sure the amp is connected correctly.
I might even remove the amp totally just to see what I get.
Read that: http://www.geocities.com/Figbert/antennasdirect91xg.htmldodge said:Winegard HD 8200P
Nuf said!!!!!
Jim5506 said:AH-AH-AH! The local channels are probably overloading the tuner when they are amplified by the CM7775.
You might try a Winegard HDP-269 preamp, it has lower overall gain (12dB) but also has a very high overload tolerance.
ralfyguy said:
MI_GTO said:That's what I thought, however, I was able to pick up the Lansing stations with a Zenith Silver Sensor indoor antenna. It even picked up Detroit on a few occasions.
tvdxer said:You should be able to receive distant stations from time to time...for example, I've had analog UHF reception here in northern MN from as far as southern MO and Detroit (it's my hobby, TV DXing). Now, are you saying you received Lansing on an indoor antenna on a normal basis, but can't see on it on your 4228? If this is the case, there might be something wrong with your antenna setup. What height it is at? This is crucial, especially for long distance UHF reception. The higher is always the better.
Correct, that's probably your problem.MI_GTO said:I have been told that I am overloading the tuner in my 622 by amplifying the signals from towers within 5 miles of my home. I wasn't sure if that was possible or not.
Limited time offer
