I have a 90 cm on a stab hh90 mount on a tripod that no matter how hard I try I can't plumb the mast that is in the tripod so I am considering a roof mount on an old direct tv dish j pole that already in place
There's no advantages for a motorized roof mounted dish, versus one mounted on a ground pole. There are however MANY disadvantages, here's a few:
1: Mount could leak during rain, and you won't discover it until it causes expensive damage.
2: BIG windstorm could rip it off the roof, then cause even more damage as the dish skitters to who knows where.
3: It can be hard to get the whole thing installed and peaked properly, because the average homeowner doesn't have the proper equipment to do it right once and DONE. So, many trips up a ladder, make tweaks, climb down, check tv, is it ok? Back up the ladder! WHOOPS, I fell off the roof!
Lots of disadvantages. Only two pluses that I can see to are roof install:
1. Allows someone who doesn't otherwise have a clear view of the arc to put up a dish.
2. Depending on your neighborhood, it would keep the kids away (think vandals)
Best to avoid it if possible.![]()
this where i would mount the dish on the roofHigh winds on the roof could knock the dish out of alignment, then it's up to the roof you go. It can happen on the ground too, but much safer and convenient. As was said by FTA4PA you might consider putting it on the roof if there major obstacles to the satellite.
Pole mounts have the least moving parts too in comparison with J mounts have extra bolts to deal with that can cause the dish to shift, loosen, etc.
Believe it or not there is an old colonial house in the next town with a 10 foot dish mounted on the roof ! I could not sleep nights if I lived in that house.
do you adjust the motor latitude up or down or can you adjust dish elevation up or down ?Do you know that the J pole is plumb?
Another thing to consider is that if you can get your tripod mount to be level in the east/west axis, you can compensate for it not being level in the north/south axis by adjusting your motor latitude.
Tri-pods, at least the ones made to hold up TV antennas, are not really stable enough for larger FTA equipment.
Looks like your house is one story and mount is very near the edge of the roof? If so and the mount is plumb then it might be workable. You would have fairly easy access to the dish by just putting a ladder against the house. Not much worry about clearing snow/ice off dish in Texas.this where i would mount the dish on the roof
line of site issues is the big oneThere's no advantages for a motorized roof mounted dish, versus one mounted on a ground pole.
Cham is right. I would not use a tripod designed for an OTA antenna for an FTA motor/dish combo. KE4EST is correct .... make a permanent pole install.View attachment 106093 this is the tripod i bought http://sadoun.com/Sat/Products/Install/EZ463A-3ft-tower.htm that when i tighten the bolts to the 2" mast the mast still moves thus the reason i was considering a roof mount
Limited time offer
