What are those colored buttons for? | SatelliteGuys.US
CK SatGuy
Formerly ckhalil18
4,023
112
The Motor City
This is a question for everyone whose has a 20.0/21.0 remote. Does anyone know what those four colored buttons located above the DVR button are for? I read the user manual on DISH's website and it said they're shortcut buttons for future use, but can someone here at Satguys give me a better explanation. I know the 32.0 remote has those same buttons and the red one is for "jump" (don't know what that means) but do the 20/21.0 remotes do the same "jump" thing as well? Any info would be appreciated.
As far as I can tell on my 722K the colored buttons are currently useless. Maybe if you program the 20.0/21.0/32.0 remote to control a DVD player that uses the colored buttons they would work on that device. The 32.0 on the 922 uses all 4 colored buttons, depending on which screen you are on. The problem with the 922 is the color button codes that Logitech has/had for the 32.0 didn't/don't work correctly on a 922. I haven't tried my Harmony remote in several months so that may have been corrected.
I use the colored buttons for other devices. For my receiver I them to change inputs. For my projector with distinct on/off keys I use one of them for the off.
I love the colored buttons. I have them programmed to perform tasks on my AV receiver that don't work with the standard code for the receiver.
I use them all the time. They don't have any function with the satellite receiver, but they work great programmed for other devices. I use them for TV and Bluray menus (left, up, down, right). Very handy to have.
I use mine all the time. Red opens my garage door, blue starts my coffee maker, yellow starts my truck on those cold mornings. Haven't found a use for the green button yet though. :)
ROFLMAO!
Sent from my DROIDX using SatelliteGuys
I tried. The 722k has no codes for Bluray players and won't "find" one. I did a chat online and was told by a csr that right now you can't control a bluray with the Dish remote
Just use the code for the same brand DVD player. I bet it will work
Since the 20.0 & 21.0 remotes are learning remotels you can teach it every button you need using your blueray remote it will control your blueray.
Sent from my DROIDX
I'm not sure on the red & green buttons, but if you are in your guide menu scrolling up and done to see what's on, the yellow and blue buttons are secondary scroll up & down by 5 channels like the 2 round buttons with up and down arrows below aux & dvd. Yellow is up, Blue is down, but only works in the listings guide.
DVR pause actually skips ahead
Installation Comment
