What are you getting for signal on g10 with winegard 76cm | SatelliteGuys.US
drhydro
1,572
During a break in the clouds i went out and with my daughters help tried to peak my 76cm with .5 db lnb on g10. The best sq i can get on 11720 is 35-39 (using her satworks). Just wondering what other people who are using a 76cm dish are getting for sq on that notoriously weak tp and what you are using for a lnb.
I am considering changing what dishs I have pointing where, and pointing my p* at g 10 and my 76cm at amc3 (for montana pbs) if that will give better signals.
i only getting a 40 to 43 quality reading with my8.5' dish and satworks can't even get a lock when using the fortec ultra on same dish.:(
finally the clouds moved away
30" Winegard with a .3 Invacom Quad
11720 TP
38-Fortec
45-Pansat
11799 TP
65-Fortec
70 to 72-Pansat
Doc
I just aimed a 76cm HotDish at AMC3 and I can pull a 45-47 for Montana PBS. Using a .5 LNB
Also the Satworks does read a little low on the quality meter. Its stable but low
Thanks Iceberg, guess i will have to move the p* over to g10 and put the 76cm on amc3. I think my lnb is starting to "drift" a little on the 76 cm, might have to try a newer lnb on it. I hadnt been using it much over the winter, as it lost signal quickly during snow storms, a problem i dont have with the BUD.
traxis 3500, 85cm elliptical dish, .3 lnb (Extreme II)
11720 TP
50 - 60
11799 TP
73 - 75
1M Channel Master with .4 Kul2
Im not getting much of a varience. My coship 2300b pegs out but the traxis 3500 comes back with
11720 - 74
11799 - 73
2006 Upfronts
golf channel?
