WHat dish need for my local | SatelliteGuys.US
trido
440
17
Southern indiana
IS there any place on the net where I can tell what dish and or how many dishes need for my zip code?
I may go DIRECT for Football and like to know more details on direct hardware for my local.
Thinking it is a 5 LNB if so is that using TWO dishes
thanks
for any info
Trido
Evansville,In 47710
If you are getting HD channels, you will need the 5 LNB dish plus a second 18 inch round dish to receive locals. If your not getting hd, you will probably get 2 18 inch dishes.
Is the 103 higher up...
Rain fade... without the rain
