what do I need sat 72 and 129 or 119 | SatelliteGuys.US
acidomiami
2
bermuda
Hello I think this is a begginer question
I'm want to get the most channels showtime hbo and movies better if is hd
Where I am the best signal I get is bird 72 ( I have a 4ft dish for that one), and I have a 8ft dish but I have to decide betwen 119 or 129 (the only ones I have signal), and a few legacy directv/ disnetwork LNB's
I Bought
1 dish receiver (DISH Network vip 222)
1 [FONT=verdana,helvetica,sans-serif]DISH Network DPP-44 wiht power injector[/FONT]
Questions:
1 best configuration of dishes I can use 72 and 119 or 72 and 129?
2 Do I need any special LNB or switch, are Hd lnb,s differents
3 witch one is the best package to subscribe to get more movies hd and sd
Regards
Sebastian
SD core programming and some HD is on the 110/119 set which is basically the same as 72/77 set. The HD is on 61.5 or 129. So basically you'll need a 110/119/129, 110/119/61.5, 61.5/72/77 setup... or the kinda odd one of 72/77/129.
welcome
I Bought
Questions:
Regards
Sebastian
Welcome to the forum. :welcome. Digiblur is right. I've got the kinda odd 72.7/77/129. Easier look angle here than normal 110/110/129. I have 3 individual dishes but since I had a .9 meter dish pointed to 129 before I move here it was easier to repoint it to 120 again. Then when I got the other dishes here I wanted my locals all in MPEG4 so went with 72.7 & 77. I also "moved" So that I could get all my locals in HD. Only 2 of my LIL are in HD where I live. When I move come next month about 130 N of here I will again "move" to another LIL so I can get the CW in HD as well as the big 4.
thanks 4 the fast response
Where i can see a Sat/channel list other than lingsat
the lmbs shitches and box I have are compatible?
Thanks Again
Sebastian
One channel bad, other good - same satellite.
Questions about 722k
