What do I need to carry my 622 to a 2nd home | SatelliteGuys.US
morleyz
5
We have a vacation home and rather than setting up a separate account or stacking...I'd like to just carry my 622 back and forth as needed (and as many appear to have done).
I don't know a ton about sat. equipment, but I'm a pretty handy guy, so I was thinking I could just buy the necessary dishes, mounts, etc and install myself, but I'm not completely sure what I need. I have two Dish 500s at my primary residence with the 622 and a SD DVR connected to them.
Can someone assist me with a parts list to run my 622? Also, the vacation home had DirectTV installed and everything is still there (and it all looks pretty new)...so if I can reuse any of the mounts or cable, that would be cool.
Thanks.
Thanks.
Call Dish or chat online with a csr at DISH Network - 1.888.825.2557 and request info on the Dish snowbird policy. If you have HD tv at the vacation home, you will either need a triple lnb dish, I think it is a 1000.2 or a dish 500 for 110/119 and a single dish for 61.5, depending on your location. Dish may do this for free. As far as the direct mounts and cable, they are interchangeable. Hope this helps.
Call Dish or chat online with a csr at DISH and request info on the Dish snowbird policy. If you have HD tv at the vacation home, you will either need a triple lnb dish, I think it is a 1000.2 or a dish 500 for 110/119 and a single dish for 61.5, depending on your location. Dish may do this for free. As far as the direct mounts and cable, they are interchangeable. Hope this helps.
Great. Thanks. I chatted with DISH and they said they would make a notation on my account and that's all I needed to do at this time.
The downside is I still need to figure out the dish configuration. Can someone point me in the right direction to determine which configuration I need for my area. At my primary home I have Top 250, HD Gold/Platinum and locals (The vacation home is about 100 miles away...so I'm not sure if locals work or not...but it would be nice).
Sorry, I had to do some research. Based on your location, either setup that I mentioned earlier will work if you will have an hd set at the vacation home. If you will not have hd there, then all you need will be a dish 500. Your locals will depend on the zip + 4 code of your vacation home. I suggest you email tech@echostar.com, give them the exact location of your vacation home and they can tell you exactly what you need. Be sure and mention that you are a snowbird.
If you have DHPP E* will do the install free as a Dishmover. Otherwise I think it may be $99. For your location you could use a 1000.2, 1000.4, or a 2 Dish 500 setup. You won't need any switches and can use the cable to feed one tuner. If you are taking both receivers you'll need a second line from the dish to the second receiver.
A simple request for posters
