jchapa said:How do you find out wich type the Dish 500 is? Legacy or DISH PRO?
DISH's current production is DISH PRO products, Legacy is still being supported but at some time in the future will no longer be supported.MarkG said:K R Kimmel,,good info thanks. Here is a followup. Since a DP 301 or 311 will work with either DP LNBs or Legacy LNBs,is there any benefit to use the DP LNB over the Lagacy LNB ?? Other than not working with Lagacy receivers,whats the difference?
Limited time offer
