Beware of stretch-o-vision. Just because you're watching an HD channel, and the picture fills up the screen on an HDTV (in normal mode), it doesn't mean the source is HD, it could be upconverted/stretched SD. This is not an issue with Dish. The networks are broadcasting this way (TBSHD is the worst).Very intersting. THANKS!!!
So lets see if I understand. If I a wide screen TV and I have the aspect ratio in my HD setup (in the Dish menu) set to 16:9 when I tune in a show and it says normal but takes up the entire screen is it safe to assume the program is HD? If I tune to a non-HD program it will have black bars on the right and left correct?
When you look at the info for the program you are watching (i.e. hitting the right arrow/browse button) there is a box in the upper left-hand corner that says "Normal". What does this mean?
Thanks in advance.
Derek
It means it's time to read the manual.... who knows what other great features you're missing out on....![]()
Nice that you put a smiley, but how was that helpful?It means it's time to read the manual.... who knows what other great features you're missing out on....![]()
Tell me what page that explanation is on in your manual.It means it's time to read the manual.... who knows what other great features you're missing out on....![]()
What I want is for the receiver to remember this setting on a per-channel basis. My SA 8000HD/8300HD did it.Also, the receiver "remembers" your settings for both HD and SD. So if you have HD set to "normal" and SD set to "stretch", these settings will remain if you are flipping between HD and SD channels. If you have SD set to "normal", there will always be black bars on either side on SD channels.
Thanks in advance.
Derek
I was pointing out the fact that the 622/722 is a complicated piece of electronics with a lot of great features. Some of them aren't obvious, so a read through the manual will often teach you new tricks.
Chapter 2, page 18.
Let's see....Chapter 2, page 18.
Limited time offer
