What gives with Cozy tv?. | SatelliteGuys.US
perkunas
36
Ontario Canada
I thought SES 3 was suppose to make things better, a nice new satellite more power.
I used to get Cozy tv, well...sort of, I had to tweek it. Now I get nothing, after they put up the new satellite.
Did they take it off the air?.
Nope, I've been watching it non-stop since the satellite change. Perhaps you need to rescan. You DID remember to change the skew on your lnb, right? It no longer needs that crazy-skew to work.
Change it to whatever would be normal for this sat location at your place
If it wern't for bad luck I would have none at all!
Does old fta receivers work now?
