They're on 119W.Does any body know what happened to CTV , it comes in with a good signal but black screen. Is it done for good or did it move again?
119 degrees?
Yep, 119wDoes any body know what happened to CTV , it comes in with a good signal but black screen. Is it done for good or did it move again?
119 degrees?
4020 V |
DVB-S2 QPSK |
30000-5/6 |
Mine is set on 4019 30002 I was watching until Dec1, now coming in at 98 but dark screen. Did they change something or do I need to reload this sat.Yep, 119w
4020 V DVB-S2
QPSK30000-5/6
They seem to be scrambled, $, I can't make them come in. Blind scan got shopping and aYep, 119w
4020 V DVB-S2
QPSK30000-5/6
I have a Linkbox 9000 i 10 foot dish C bandI just brought up 3 CTV services on 119W. Look fine on my 12 footer.
looks like maybe you're not on 119W C-Band. I don't think there's any shopping channel there. Can you give more information about what you are receiving? like channel names and frequencies?They seem to be scrambled, $, I can't make them come in. Blind scan got shopping and a
Chicago station.
There is a mux for WGN on 125 West---but it is scrambled. That's probably where they are.If you got scrambled stuff on 4020 then you're on the wrong sat. I don't see any Chicago stations on 119W C-band either.
Ok, the TP is 4148 and 13750, and 127 degrees,I did a blind scan. This gets the Chicago station Its just a test pattern that says Chicago.If you got scrambled stuff on 4020 then you're on the wrong sat. I don't see any Chicago stations on 119W C-band either.
Limited time offer
