what home theater systems work with the 811 | SatelliteGuys.US
ww2154
44
I am thinking about buying a home theater system. I think I have read in the past some did not work with the 811. Does anyone know if a koss system will work with the 811.
maybe i am stupid but i see no reason any system would not work if it is at least modern
I think you are refering to some posts (that I can't find) about dolby digital acting strangely with some Dish receivers. Not sure if it was just the 811. I can't answer your Koss question, but I do know that my 811 (when I had it) and my 921 both worked fine with JVC, Denon, Sony and Pioneer receivers.
Yamaha works fine.
It's not the "home theater system" but the A/V switching head unit (aka receiver) that can be the culprit. Make sure it accepts & decodes the full range of sampling rates all at once ( or at least up to 96kHz).
I have a Yamaha 2400 and it works fine with one minor complaint.
The onscreen display (volume etc) does not display with the component input from the 811 ( or component from the DVD). It does work with the 522 (S-video). I was told by a Yamaha tech (email exchange) that it will not work. While I have not been happy with this one small glitch, I have learned to live with it.
I wonder if this problem applies to all receiver brands, or just Yamaha, or is acutally specific to my model 2400.
This is definitely a receiver based issue having to deal with OSD on Component outputs and I would suspect not 811 specific. I would also guess it is model specific and other models might support this feature.
522...is anybody happy with theirs?
OTA DTV Channel Surfing
