What is KU Band.... | SatelliteGuys.US
What is KU Band....
  • Thread starter Thread starter PSB
  • Start date Start date
  • Replies Replies 0
  • Views Views 19K
PSB
On vacation
3
5
The Ku band ("kay-yoo" kurz-under band) is a portion of the electromagnetic spectrum in the microwave range of frequencies ranging from 12 to 18 GHz.
Ku band is primarily used for satellite communications, particularly for satellite backhauls from remote locations back to a television network's studio for editing and broadcasting.
Ku band is split into multiple segments that vary by geographical region by the International Telecommunication Union (ITU). Several highly used segments in the Americas (ITU Region 2) are:
The 11.7 to 12.2 GHz band is allocated to the FSS (fixed service satellite, uplink 14.0 to 14.5 GHz). There are more than 22 FSS Ku-band satellites orbiting over North America, each carrying 12 to 24 transponders, 20 to 120 watts per transponder, and requiring a 0.8-m to 1.5-m antenna for clear reception.
The 12.2 to 12.7 GHz segment is allocated to the BSS (broadcasting satellite service). BSS/DBS direct broadcast satellites normally carry 16 to 32 transponders of 27 MHz bandwidth running at 100 to 240 watts of power, allowing the use of receiver antennas as small as 18 inches (450 mm).
Ku-band signals can be affected by rain attenuation (rain fade).
NBC was the first television network to uplink a majority of its affiliate feeds via Ku band in 1983.
KU signals have a 5 digit Frequency (eg. 12052 )
Standard KU LNB's use an L.O. of 10750
Universal KU LNB's use an L.O. of 9750-10600
DBS LNB's use an L.O. of 11250
Who Read This Thread (Total Members: 10)
