what is my true south Latitude: 40.9653° Longitude: -75.9981° | SatelliteGuys.US
djflako
21
United States
hy everybody just a ? what is my true south Latitude: 40.9653° Longitude: -75.9981° trying to put up a dish with a motor sg2100 and a 36" dish sv360 elite sv 4000 is the set up thanks in advance
dishpointer.com has a pretty comprehensive list of satellites.
If it isn't obvious, you're looking for one with the same longitude as your own (-76W).
The neat thing about dishpointer.com is that you can enter the numbers you gave us " (40.9653,-75.9981) " and it will tell you the elevation (42.6) as well.
You won't receive any signals from 77W unless you have a circular LNB on your dish. Best to try for feeds from AMC6 @ 72W. Or try for AMC9 @ 83W. On AMC9, tune for RTV at 11735 H 4439 or the strong data transponder at 11840 H 26666.
What is this?
Rasberry pi
