What Is The Best Dvb Software Out There? | SatelliteGuys.US
goaliebob99
14,487
521
hey this software is crap that came with my twinhan.. I cant scan satellites and transponders on the fly to update frequancys of transponders .. like how you can with a normal fta box... what is the best software that will work with this card and whats the pros and conns of all the software out. What would you all recommend?
You're using a Twinhan 102G, the same as me; there is no blind scan.
Your best bet is to use ProgDVB and scan through the transponders in the list. Which I think the Twinhan software would do just as well...
CharredPC
I like ProgDVB but my computer is a little slow for it. I have also used RitzDVB. Or you can try MyTheatre. TVedia is a little like Windows Media Center, but uses the MyTheatre dvbcore. You can try any of those for free.
I myself use MyTheatre, only becuase my setup is used by the Wife (needs to be TV friendly and remote-control driven). Ok, I admit, I enjoy that setup too.. Oh, that and ProgDVB crashes everytime quality gets low on my machine ;) But I'm a rarity in that aspect.
SG2100 Help!
Another SG2100 Mounting Question
