I was wondering if anyone has both C1PLL LNB and the lite one to tell me the difference between the two? Thanks
MY understanding is there are two basic differences:I was wondering if anyone has both C1PLL LNB and the lite one to tell me the difference between the two? Thanks
Good comparison FTA4PA!
The C1PLL and C2PLL housings are much higher quality than typical competitor LNBFs. They are provided with upgraded zinc coated Allen head screws and hex head tool. These models are pretested to stringent specification values to provide the highest performance. This is not to say the lite model cannot have the same spec and performance, but the lite model grading allows for more deviation within the spec.
The lite model is designed for the value conscious buyer who simply wants a PLL upgrade from their DRO or a standard entry level LNBF. The simple lite housing with standard hardware and lifetime limited warranty is a great option for the regular viewer of average c-band signals without requirements for higher quality hardware and tighter specs.
Limited time offer
