jpesc said:
I have a 622 with the IR/UHF remote, I also have a UHF Pro, is there anyway to control tuner one through UHF so I can use the UHF Pro on another TV.
It sounds like you have the 622 in the living room with TV1 Output connected to the TV, then the kids watch TV2 Output in another room, and when you go to bed, you would like to control the TV1 Output from your bedroom.
I would like to do the same. I've read all of the data on the 622, web sites, owners manuals, and sales propaganda. On one of those it implies that you can control TV1 using UHF from the Aux button on Blue Remote 2, but then I could not find any more info and how to do it.
If anyone else is reading this and has more info - please pass it on.
Now if the 622 is in Single Mode, the Blue Remote 2 will (suppose to) control both TV1 and TV2 Output, but then that defeats the purpose of 2 remote rooms watching different programs.
So the only way that I can think of is to buy a "IR-to-UHF Pro Upgrade Kit" which will allow you to control your 622 TV1 Output using a UHF Pro remote. The info is on the bottom of the page at this link: http://www.dishnetwork.com/content/products/userguides_manuals/index.shtml
I think this kit will use the same frequencies as your 622, but I think just changing the address, it can be on the same frequency and will not cause any interference with the Blue TV2 Remote.
Now back to the beginning of the thread.... Here is my understanding of this.
I thought all of the (newer) UHF Pro Remotes had the extra buttons for DVR control, etc..., even if your receiver did not have a DVR. I believe there are currently 2 frequencies being used for the UHF Pro Remotes.
UHF Pro and UHF operate on different frequencies, so they will not work in place of each other.
However, the Blue 2 - UHF Pro Remote that comes with the 622 uses UHF Pro frequencies to communicate with the 622. However, in Aux mode, Remote 2, as well as Remote 1, can be programmed to send a combination IR/UHF signal to control certain other Dish receivers (but not a 622 TV2 Output).
See 622 Users Guide, Chapter 10, bottom of Page 81.
Also, I believe the first UHF remotes that came out, such as the one with my EchoStar 2000 receiver, is different than the later UHF Remotes and/or UHF Pro Remotes.
EDIT: On the 2000, I think there was 3 models, the first 2 only being IR, and the last one being only UHF - but someone on the www has instructions for converting the UHF only model to IR/UHF.
