What is the Difference of Universal 1 vs. Universal 2 on the Geosat 1100c | SatelliteGuys.US
Pixl
Senior Member
1,902
67
Traverse City, Michigan
In the Geosat 1100c menu for lnb setup there is two universal settings. Anyone know what is the difference? Got my C/Ku combo lnb to work recently without the help of instructions. Turns out the Ku section is a universal lnb. I am using a Gospell GKC-D002. I understand it may be the same as the GEOSATpro CK1u and could use some installation instructions if anyone has them.
Jim
Universal 1 = LO Low: 9750 LO High: 10600
Universal 2 = LO Low: 9750 LO High: 10750
What do you need to know about installing a C/KU LNBF?
Brian,
Thank you for the info on the Geosatpro 1100c. I also need to know how to set the F/D ratio on the lnb.
Jim
Help me pick my new FTA HD reciever!
DiSEQc Switch and DirecTV Receivers
