What is this dish that everybody sells here | SatelliteGuys.US
nuatitud22
2
Living in Puerto Rico now and things are different here. Looking for a Fortec, Andrew etc 120 or 180 dish but can't find any brand that I know. Seems as though everywhere I go they have Azure Shine, they call them 4.5 and 5.5 but I assume that they are 120 and 150's. I did look up the company and they are a Taiwan made dish. Does anybody know anything about them, good bad or indifferent. Is Geo sat Pro connected to them in any way. Help please, Can't afford shipping from USA to here, almost 400.00 for a Fortec 180 for shipping but I don't want to buy junk either. Want to connect a Sonic View 360 Elite to a hh120 if I buy the 120cm or the actuator if its the 180cm. Will be using a Invacom Qph-031 lnbf.
I have an Azure Shine dish, and they work fine. They are just a generic type, so the instructions suck. You might want to change the screws/bolts with a better type, as they are so soft, you'll break at least 1 installing it. OH! and make sure it's not popped out of shape when you install it! Before putting the arms on it, grab the dish on each side with the bowl front facing you, while holding it in the air, kind of shove it away from you, and then pull it back towards you fast. It'll force the dish to automatically POP into normal shape, if it was shipping deformed slightly.
IF Frequencies
??Turner??
