What is this? | SatelliteGuys.US
What is this?
Sat Monkey
99
Wausau, WI
I work for a Dish network retailer, and I did a Direct to Dish change over and I found this inline with the sat feed connected to the receiver.
What is it?
I have heard about a high freq. signal amp.
Is this one and the same?
boogar420
Just wondering and if it works with Dish.
Monkey
What is it?
It almost looks like a signal trap the cable companies use for internet setups. I don't think that's what it is, though.
I know we use them with the UHF remote antenna to filter out unwanted noise.
I have never seen one used inline with a sat feed.
Weird
Monkey
I had one come in with my HR20 - 700 , it's an attenuator I believe... (never used)
I think it is an attenuator. I recall an issue where receivers very close to the dish would not work with the new signal verification program. The cure was to add a bunch of line to attenuate the signal down to a level the signal verification junk would accept. The eventual cure was to add an attenuator and save the cable.
Joe
When I was with dish network I need to get one to filter the signal so my two RF remotes did not take controller of the other box. In short it cuts the RF signal.
New DirecTiVo DVR
Auto Expanding SD Picture
