what other satellites can i? | SatelliteGuys.US
Buzzdar
735
USA
what other satellites can i pick up with the dish 1000.2 what else can i get instead of the 110 119 and 129
Uh, 110, 119, and 129?
Nothing else of value. You could use one of the LNB's to pick up 61.5 or 148 or whatever's visible from your region, but that'd be useless. And you'd lose your SD from 110 and 119.
Use another dish and feed it into the input on the 1k2 lnb..you can aim at 61.5 or 148.
I used a 1000.2 to get 129 and 148 from the same dish just to prove it was feasible. I'm not using that arrangement, just wanted to see if I could do it. Check my posts and you will find it here.
Hmmmm...... makes me wanna build a dish tree/farm for 61.5/119/110/129/148/118, oh it's gonna be beautiful, maybe I'll stick it in the front lawn ;)
As far as hobby, I'd get yourself a FTA setup with a 1 meter dish... check out sadoun.
lost my 1 italian channel.
Owning vs. Leasing
