What rec? | SatelliteGuys.US
What rec?
houli
17
you guys are great i have a ? which receiver would you fellows recommend for a first timer.
Hi iceberg and friends, i have been looking at the top 4 captive works 600, coolsat 4000 and 5000 pro, and pansat 3500, the packages, one of these systems i will be buying, to use in puerto rico, just do not know which one to get. All help will be appreciated. Thanks HOULI
I would verify first that the dish you use will work. Most of the satellites may not beam to Puerto Rico
Is there specific channel (s) you are looking to get?
Galaxy 10R
vs2000
