what sat. are the SF HD locals located at? | SatelliteGuys.US
juangomez
29
Hi,
I have a 942 and two dishes, one 500 pointing to 110/119 and a regular one pointing to 61.5.
I'm located in SF Bay area and have a good lock on HD OTA channels.
I want to upgrade my leased 942 to a 622 and I was wondering if I need to upgrade my dish as well in order to get the HD locals through the sat (that way I'll be able to record/watch more that one HD local at a time).
What sat are the SF HD locals located at?
Thanks!
= J =
thanks!
so what is the recommendation?
should I upgrade my 500 and get installed the 1000?
those HD locals in 129 won't get replicated in 61.5, that is the other dish I have, right?
and I guess I would have to pay for the installation anyway, even if I don't do any dish upgrade, right? (the $299 includes it)
Thanks!
= J =
juangomez said:
thanks!
Thanks!
= J =
Or swing your 61.5 to 129.
Thanks!
sometimes the solution is in front of your eyes and you don't see it :)
would I lose any channel that is in 61.5 and not in 129? they used to be mirrors but I guess they are not anymore.
Cheers.
= J =
juangomez said:
Thanks!
Cheers.
= J =
Only channel you will/may lose: HD Demo channel, or CBS-HD (only if waiver is accepted, but you may lose it after SF HD locals are activated.)
You'll probably get at least 10 points better signal strength with a dedicated dish for 129. I had a 61.5 dish in addition to a D500 and swung it to 129 when I upgraded to the 622. I'm located just East of you above Sacramento.
Doug
Live Retailer Chat Recap - May 18, 2006
VIP 211 Problems
