What should you do with old RG6 cable? | SatelliteGuys.US
I know this guy. He’s got maybe 500 feet of old RG6 cable spooled up in his shed. I’m talking stuff that old cable companies strung, antenna cable, cable that came with stuff that wasn’t used. It’s an impressive amount of cable and it took him decades to build it all up.
I’m kind of curious if he’ll ever find a use for it. But I get it, I hoard stuff too sometimes. Never know when you’ll need an adapter to go from 75-ohm BNC to PL-259. Just because I haven’t needed one since 1987 doesn’t mean I won’t need one tomorrow.
Seriously though, is there a downside to keeping old RG6 cable?
It’s the real world and stuff degrades​
Even with the best care, RG6 cable is going to degrade over time. The outer jacket could get brittle with sun and heat exposure. The dielectric, which is that white foam stuff in the middle, can break down. Even the copper won’t last forever in pristine form. No cable is 100% air tight and eventually the copper is going to oxidize, turning first dull brown then green, by which time it will be utterly useless for carrying signal.
The amount of time it takes for a cable to go from pristine to useless really depends. In a dry, temperature controlled environment like your home, it can take 25 or 30 years before a cable gives up. Outside though, especially in the brutal southwestern heat, I’ve seen cables that were ready to be replaced in 5 years.
Be aware​
If you’re going to save old cable, or anything that carries signal or electricity, you probably ought to make a habit of taking a look at it every couple of years. A cable that worked great just 5 years ago might have turned into an oxidized mess. It’s more worrisome if that cable is carrying current. While electrical wires tend to hold up for an insanely long time in the walls, there’s no promising that a wire you have hanging in the garage will.
Keep your cables as long as you want, I’d say, but be prepared that they may not be really good when you need them. When you think about it that way, maybe you don’t need to keep that paint-spattered RG6 cable from 25 years ago. Maybe you’re just better off buying something new when it’s necessary.
Luckily for you, the best professional-grade cable can be found at one place: The fine folks at SolidSignal.com. You can get the exact length you need, brand shiny new, exactly when you need it and there’s no need to go through the cycle of hoarding, inspecting, and culling for all of those old cables so long left behind by installers.
A lot more than cable​
You’ll find thousands of pro-grade parts when you shop at SolidSignal.com. These are exactly the same parts the professionals use and they’re available to you at the best prices. But, there’s a lot more to a professional installation than just the parts. That’s why you need a partner who has the expertise to do it right. Our Signal Connect division provides full service solutions for homes, offices, vehicles, industrial and governmental locations. We can handle the most complex installations and we have decades of experienced and certified technicians ready to help.
Call the experts at 888-233-7563 and get the kind of advice you need. Phone calls may seem kind of old-fashioned today, but that’s who we are. We provide the kind of service that most people didn’t think existed any more. You’ll be glad you called. We’re here during East Coast business hours. If it’s after hours, fill out the form below. We’ll get right back to you!
The post What should you do with old RG6 cable? appeared first on The Solid Signal Blog.
Continue reading...
If it ain’t broke…..
Anyway, I know a guy, Vinny, who gladly takes my old coax. He and Guido showed up, and they gladly took a few old cinder blocks I had laying around, along with the coax. Kinda odd how they tied off one end of some of the coax onto a couple of cinder blocks. Well, no concern of mine!
  • Wow
Reactions: telstar_1
I have done a lot of work in MDU's installing SMATV systems. It is not uncommon at all to see the original RG-59, which was installed in the 70's, to be in excellent condition. Not sure I believe the 25-30 year lifespan comment on an indoor coax.
